TB Bypass?
Old Apr 6, 2005 | 04:31 PM
Black94Camaro's Avatar
TB Bypass?
I know im probably in the wrong forum, but i only hang out in the V6 forum. What exactly does a TB bypass do? TB Spacer is the same thing right? How much HP would it add? Worth the cash? Would it be a big deal for a V6? Im just curious, slowly learning about modifications on cars.
Old Apr 6, 2005 | 04:54 PM
MarcR94v6's Avatar
Re: TB Bypass?
Hey cool, I have the same car as you except mine is Aqua (I don't like the color, but can't bring myself to get a paint job when the money could be used on something better). I'm also quite new but I'll try to help to the best of my ablity. A Throttle Body bypass kit will add more cool air into your engine and give you more horsepower (like 10 I think). I was thinking about getting one myself. And I'm sorry, but I've never heard of a TB Spacer, I'm new too afterall. I'd also like to know more though....like who makes good ones? and about how much should I expect a good price to be?
Old Apr 6, 2005 | 04:56 PM
deadmeat2004's Avatar
Re: TB Bypass?
more like 1hp... do a search.. this was discussed recently.
Old Apr 6, 2005 | 04:59 PM
MarcR94v6's Avatar
Re: TB Bypass?
1? aww poo. Well, shows what I know.
Old Apr 6, 2005 | 05:03 PM
Re: TB Bypass?
hey its free!!
http://www.fbody.com/tech/
look at some of that...
Old Apr 6, 2005 | 05:06 PM
MarcR94v6's Avatar
Re: TB Bypass?
thats for a 3.8, he's got a 3.4, will it matter for this?
Old Apr 6, 2005 | 07:35 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
Re: TB Bypass?
TB bypass on a 3.4L ... gains ... none, however every little bit counts right?...
what you need is a set of pliers an eye (only one is necessary) and 2 hands are helpful although you might be able to do it with one
look at the bottom of the TB... you will see 2 hoses going into the TB from a coolant line
take your pliers and pinch on of the hose clamps so it opens and pull the hose off the TB
now pinch the take the other hose clamps on the other hose going into the TB and off the car completely
take the hose that is attached to the coolant line and plug it to the barb that is left from where you pulled the other hose from
attach the clamp and you are good to go.. take it for a test drive and notice the lack of gains
Old Apr 7, 2005 | 07:08 AM
99blackSS's Avatar
Re: TB Bypass?
Gains are none really. It keeps you from losing power when the car is hot the amount you would no longer lose would be around 1-3hp. For how cheap and easy it is to do, I would do it.
Old Apr 7, 2005 | 08:07 AM
Re: TB Bypass?
right! You dont need to spend the money on buying a kit. you can do it with the original hose that you already have.
Old Apr 8, 2005 | 12:47 PM
Re: TB Bypass?
in the summer time it will get 115 here, should i get a 160* or a 180*, or NOTHING!
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
