Traction Control
Old Mar 29, 2005 | 12:16 PM
SickWS6's Avatar
Traction Control
i have a 96 Trans am and it has traction control but there is no way to turn it on and off. its always on. i was just wondering if there was anyway to put a switch in the car to turn it off and on? and how would this be done
Old Mar 29, 2005 | 12:54 PM
teke184's Avatar
Re: Traction Control
unless someone removed the switch....
any car equiped with traction control has a way to turn it off.
why do you think you have it? when you do a burn out does it kick the gas pedal back at you?
if all its doing is showing a dash light or "low trac" or something...that's normal...doesn't mean traction control.
Old Mar 29, 2005 | 01:56 PM
rskrause's Avatar
What the man said!
Rich
Old Mar 29, 2005 | 02:02 PM
SickWS6's Avatar
there is a dash light that says trc off and it isnt on and the manual for my car says that i have it and shows where the switch sd and there isnt the switch there so i know that i have it but there is no switch
Old Mar 29, 2005 | 02:12 PM
eagleknight97's Avatar
Easiest way to figure out if you have it is to see if you have that huge ugly black box on your driver side valve cover. If you dont have it, then you dont have traction control. And if your car had traction at one point and the previous owner removed it, then your computer would be showing trac off and your abs inop light should also be on because you have OBD-II and you cant just remove the traction control motor and program it out of yoru comp. There is alot of other stuff involved in succesfully removing traction control and retaining your cruise and ABS on an OBD-II car.
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
