Deleting EGR
Old Mar 25, 2005 | 11:29 AM
LoudmouthSS's Avatar
Deleting EGR
How can i do it?, What problems will i run into?
Old Mar 26, 2005 | 09:49 PM
92BLKL98's Avatar
Re: Deleting EGR
I plan to do this but itis going to require some tuning to make it work. My interest is to work toward the LT1 intake mod.
Old Mar 26, 2005 | 09:57 PM
Randy92Z's Avatar
Re: Deleting EGR
You can remove it, but it will set a code, unless you have your chip re-programmed to have the EGR turned off.
Old Mar 26, 2005 | 10:17 PM
cc89formula's Avatar
Re: Deleting EGR
You can do like me, just rip it all off and then stare at that damn SES light....
Old Mar 26, 2005 | 11:08 PM
Re: Deleting EGR
what bout block off plates and stuff?...yea i can care less bout that SES light lol
Old Mar 26, 2005 | 11:33 PM
Re: Deleting EGR
Thats what I thought, but the whole way home it was just staring at me. I couldnt take it.
Old Mar 26, 2005 | 11:40 PM
Re: Deleting EGR
lol...yea true.. heh
Old Mar 27, 2005 | 12:54 PM
Re: Deleting EGR
besides getting rid of the egr...what else can i remove?
Old Mar 27, 2005 | 12:59 PM
Randy92Z's Avatar
Re: Deleting EGR
Air Pump that will free up some space and weight under the hood. Ditching the A/C will take it even a step further on space and weight. If thats what your looking for.
Old Mar 27, 2005 | 02:27 PM
Re: Deleting EGR
heater too. But i like the ac and heater, mine are staying.
Old Mar 27, 2005 | 03:52 PM
Re: Deleting EGR
yea fl = hot...ac stays lol. But yea im just trying to clean up that jumbled mess under the hood. The engine is being pulled soon so im gunna clean everything up, repaint the compartment and scrap all the crap i dont need. So the egr and air pump...sounds good
Old Mar 27, 2005 | 05:32 PM
klumb15's Avatar
Re: Deleting EGR
switch to a carb..that cleans it up a bit ...ac delete makes a huge difference, escpecially if you get the 1le box like i did...airpump delete also makes it alot easier to get to the plugs too...new intake i think is the biggest thing to make it look cleaner...stealth rams look awesome under the hood...
Old Mar 27, 2005 | 07:32 PM
Re: Deleting EGR
heh, yea i like fuel injection, so no carb for me. I was going to swap to a stealth ram upon reassembly. But yea the air pump and egr are deff gunna go. My a/c i believe works, but im not even sure<not charged> lol, if it doesnt..then bye bye.
whats the 1lE?
Old Mar 27, 2005 | 10:16 PM
anthony714's Avatar
Re: Deleting EGR
why do you wanna rip egr off..first you aint going to see much of an increase if any..secongd it shouldnt set a light off cause an egr if i recall is only an output signal and that shouldnt set off light unless you unplug the electricall conector..just remove the egr valve or just unhook it and plug the vacuum line..the comp dont know if the vacuum line is unhooked as long as its plugged..what exactly are you looking to do?make horsepower?lighten car?go fasteR?????
Old Mar 27, 2005 | 10:58 PM
Re: Deleting EGR
actually..its just ugly and in the way, so i want it out of there. ANYWAY, where can i find some block off plates?
