Bronze or iron distributor gear
Old Mar 24, 2005 | 01:37 PM
Tweaked Zed's Avatar
I heard that bronze oil pump drive gears don't hold up with high volume oil pumps. Is this correct? I have a new #8513 MSD oil pump drive with a bronze gear driving a Melling HV155, and just want to make sure I don't have any problems with it. Any body know? Thanks.
Old Mar 27, 2005 | 06:48 PM
LT1 1980 malibu's Avatar
Re: Bronze or iron distributor gear
They dont hold up as long..Truthfully it wont do any harm when it goes out..The worst that has happened to me is that it got all chewed up and left me stranded for a few till i could get the trailer to me..If your cam requires a bronze gear then you really have no choice..Your other option is to run the iron gera and have iron chips killing your insides..Bronze gears are designed to wear out because of the cam being made from steel at the oil pump drive..
Old Mar 27, 2005 | 07:27 PM
jonaddis84's Avatar
you do have another option, comp cams polymer distributor gear.
Old May 12, 2005 | 12:13 PM
TCAL95Z's Avatar
What part number is the Bronze gear and where can I buy it?
My Joe O Solid roller cam requires a bronze gear.
Thanks
Tom
Old May 12, 2005 | 07:43 PM
1racerdude's Avatar
Crower makes the longest wearing bronze gear on the market.
Old May 13, 2005 | 04:46 AM
SABLT194's Avatar
What is the gear in a stock LT1 made of?? I'm about ready to bolt up the intake and I would like to know if I need to swap gears for my HV pump.
Thanks
Steve
Old May 13, 2005 | 11:47 AM
1racerdude's Avatar
Thanks
Steve
Ya don't swap gears for the pump,it's if the cam is compatible.
Old May 13, 2005 | 02:22 PM
TCAL95Z's Avatar
You are the man. I should have just emailed you to begin with.
If I call Crower is there a certain part number to ask for? I know there is a certain size opening that is needed.
How long do these gears normally last?
Thank you,
Tom
Old May 13, 2005 | 02:43 PM
1racerdude's Avatar
Thank you,
Tom
Talk to Dave Crower and he will plumb you up on which one.You will have to have the shaft size to get the right one.
I have run them better than 2 yrs and still good.
Old May 13, 2005 | 09:41 PM
TCAL95Z's Avatar
Thank you
Old May 13, 2005 | 10:05 PM
1racerdude's Avatar
Thank you
Anytime.
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
