no start condition after warm-up
Old Mar 23, 2005 | 08:59 AM
PapaSmurfz28's Avatar
89 iroc 350 tpi automatic...after the car warms up if you cut it off it wont start back up until its completely cooled...or if you drive it the car will surge a few times and cut off but it will start back up in that situation...fuel pump is fine...theres fire at the plugs...injectors are getting pulse from computer...any ideas ?i think it might be a wiring harness issue but why it only does it when the car warms up...i have no idea
Old Mar 23, 2005 | 11:34 AM
respectirocz's Avatar
Re: no start condition after warm-up
check the starter solenoid
it should have a heat sheild because when it gets hot it doesnt work, the heat sheild prevents it from getting too hot, when it cools down it works fine
if u dont have a heat sheild or the one u have is rusted, u can pick up a replacement at any auto parts store
Old Mar 24, 2005 | 11:43 AM
bubba353z's Avatar
My Z is doing the same thing - my buddy and I suspect that a module in distributor is going bad. I've got an MSD distributor coming as part of my planned HSR swap, but you should be able to get the module at the local parts store - if that is your problem.
Old Mar 24, 2005 | 11:58 AM
Tru2Chevy's Avatar
When you say it doesn't start, what do you mean? Will is not crank? Crank slowly? Crank fine, but not catch?
- Justin
Old Mar 24, 2005 | 12:24 PM
Willie's Avatar
A very common problem with small block Chevys. The cause is heat soak to the starter solenoid. Replace it and add a heat shield.
Old Mar 24, 2005 | 07:00 PM
car cranks over fine...and the ignition module has been replaced...its getting plenty of fire
Noenav
Mar 1, 2019 07:38 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Collector Car
Jan 5, 2015 10:58 AM
Noenav
Dec 6, 2014 07:35 PM
