Tubetype?
Old Mar 21, 2005 | 06:05 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Tubetype?
i got mickey thompson et streets... the sticker on them says "tubetype" does that mean i HAVE to go out and buy tubes as well???
Old Mar 22, 2005 | 11:43 AM
Re: Tubetype?
Not necessarily. Many of us have run the ET Streets without tubes. I think the limiting factor will be how low you want to go on pressure. Go under maybe 12psi and you run a risk of the tire deflating. In any case you MUST constantly check tire pressure, because the tube-type tires will leak air through the casing.
M/T has a writeup on their "tech" page... worth reading.
http://www.mickeythompsontires.com/tech_tube_tires.html
Old Mar 22, 2005 | 02:08 PM
frmula1's Avatar
Re: Tubetype?
so... i inflate them to 35psi to drive to the track with... drop it to 16 (warm) at the track... are they gonna leak like maybe 1 psi all day? or is there like a good chance im gonna have a flat before i leave the track?
