Panhard Bar Bolts
Old Mar 17, 2005 | 11:18 AM
BadgeZ28's Avatar
Panhard Bar Bolts
I got a aftermarket panhard bar and it requires 1/2" diameter bolts. The stock panhard bolts are metric and a stepped design. About one half is one diameter( just shy of 9/16" ) then it reduces to just under 1/2". Car brackets are drilled to accept the large diameter on one side only. My concern is if I use 1/2" bolts there will be some play in the one side of the bracket. Just curious if any of you have run into this and how you handled it? Thanks.
Old Mar 17, 2005 | 02:03 PM
Red96Lt1's Avatar
Re: Panhard Bar Bolts
I would get the metric bolts from the dealer. I'm sure they are graded fastners and I would get the correct replacement.
Old Mar 17, 2005 | 02:57 PM
BadgeZ28's Avatar
I see you have a bunch of BMR suspension parts. The rear lower control arms use this same style stepped bolt. Do the BMR replacements work with the factory bolts?
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Nov 27, 2014 09:41 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
