I want Big Brake upgrade without Big Brake price...
Old Mar 15, 2005 | 09:16 PM
LPE_wannabe's Avatar
Exclamation I want Big Brake upgrade without Big Brake price...
i'm about to order some rotors for my 98 SS and was wondering if there was anything i could do to get 13" rotors without having to buy a $1200 big brake kit from somewhere...is it true that the vette rotors are 13" and if so is there some way to adapt the caliper or will it still work with that rotor??? thanks a lot!!!!!!!!!!
Old Mar 15, 2005 | 09:19 PM
ZaneO's Avatar
Re: I want Big Brake upgrade without Big Brake price...
The C5 brake conversion will run in the neighborhood of $700. There is a ton of information about it available by searching.
C5 calipers
C5 rotors
C5 pads
LG or Bob Bishop brackets
Old Mar 16, 2005 | 12:02 AM
RE AND CHERYL's Avatar
C5 calipers
C5 rotors
C5 pads
You don't need to buy the C5 calipers and pads. They are almost identical to the LS1 stuff anyway. Brackets to adapt the stock LS1 calipers to run on the C5 13" rotors are available from several sources for under $300. Add to that OK rotors from Auto Zone and you could be done for like $400 or so. I've done this to my car and the results were awsome. BUt instead of buying brackets I modified the stock caliper mount brackets to work with the C5 rotors. Not too hard if your a compedent welder and much cheaper.
Re'
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
slocody
Feb 10, 2003 01:04 PM
