wheels didnt work?
Old Mar 15, 2005 | 08:24 PM
FNKWICKZ-28's Avatar
wheels didnt work?
I have a 93Z28 and i got a pair of ZR1 17 by 9 wheels. I put the wheels on today and the front went on with no problem. the rear wheels didnt fit on the hub, the hub was a little bigger than the wheel. So now i have to get the wheels milled out a little bit so it will fit SON OF A BITCH.
DAVE,
Old Mar 15, 2005 | 08:29 PM
v8pwrdz28's Avatar
Re: wheels didnt work?
all u have to do is file the inside of the wheel hub down a lil bit, u should see what part u need to file. i did it to my 02 Z rims i have took 10 min to do.
Old Mar 16, 2005 | 11:07 AM
The interference is a common problem when trying to put "late" model wheels on the "early" 4th Gens. The interference is only a few hundreths of an inch. Easilly solved, as indicated above, by sanding, filing, or a quick pass with a Dremel. The wheels are centered by the conical lug nuts, not by the hubs. You just need to make sure you open the hole up large enough not to rub on the axle hub.
Old Mar 16, 2005 | 02:44 PM
thanks guys
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
ChrisFrez
Nov 30, 2014 08:41 AM
