Please with "check engine" Light and random misfire.
Old Mar 9, 2005 | 04:25 AM
keng's Avatar
Hey guys i need your help. I have a 97 Z28 6-speed and I got a check engine light twice now. When we run the codes, it comes up as a random misfire, what can cause this, what can I do to fix it?
Old Mar 9, 2005 | 06:50 AM
moparman's Avatar
Re: Please with "check engine" Light and random misfire.
Did you get code P0300? If it's that, it can be tricky. It could be as simple as a fouled plug or bad wire. Or it could be the opti. Start by checking all plug wires for flaws. You also might look under the hood when it's dark and see if you can spot any arcing.
Old Mar 9, 2005 | 07:07 AM
teke184's Avatar
have you noticed any missing?
low rpm stumble? high rpm miss?
could be plugs/wires as suggested, could be bad coil, opti
Old Mar 9, 2005 | 11:55 AM
keng's Avatar
The first time I got the code it did miss and run like a$$, but when I turned the car off adn restarted it ran fine. I guess I might be screwed can has 130k
I know I need to chang plugs ans wires, butwith that many miles i guess the opti could be going out.
Old Mar 9, 2005 | 12:15 PM
-plugs
-wires
-corroded terminals
-coil
-IC Module
-Opti
-dirty injectors
The list gets sort of long. If you have access to someone with the "enhanced parameters" version of AutoTap, or a dealer mechanic with a Tech-2, they can check the misfire counts by cylinder to help locate the problem.
Suggestion.... add a "signature" so you don't have to type the year of your car in every question. Include trans type and any major mods as well. Helps people answer your questions.
Old Mar 10, 2005 | 01:52 PM
keng's Avatar
Thanks for youinfo guys, you are awesome, I will check on all this this weekend, but I noticed it did it when I dropped down to gears and reved it up a bit.
fpete1992
Dec 11, 2014 03:51 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
