Question about keyless entry
I have a 94 with keyless entry. Did the 94s flash the lights or beep the horn stock when it was locked? Mine does not do either, but I am wondering if it is because the previous owner had an aftermarket alarm at some point. There is a small hole in the dash where an LED would have been. Is that stock, or aftermarket?
Re: Question about keyless entry
Originally Posted by Kataklysm
I don't think they beeped or flashed lights until 96+. I'm guessing its an OBD2 thing.
It is when they started using the BCM (Body Control Module) in the f-body.
Originally Posted by shoebox
While it really has nothing to do with OBD-II, you are correct that those features began in 1996.
It is when they started using the BCM (Body Control Module) in the f-body.As usual, thanks homie!
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
