Track Times
Old Feb 8, 2005 | 04:48 AM
qukz28's Avatar
Track Times
I made the first trip with the car Saturday. The car has 3.73 gears, 58 mm TB, LT4 Hotcam, and 1.6 RR. The PCM is stock, havent even changed it for the gears so it hits the rev limiter before shifting. This was on street tires and the car spun a little. What would these times be in the 1/4 mile, 1/4 mile MPH. Do any of you know what the car should run if tuned and with a good converter and sticky tires. Thanks
First Pass: Second Pass:
60': 2.117 2.100
594': 8.368 8.410
1/8 ET: 8.931 8.980
1/8 mph: 79.92 78.93
Old Feb 8, 2005 | 09:36 AM
93LT1355's Avatar
Re: Track Times
I don't know if this helps but I ran a 8.957-1/8, when I ran my 13.930-1/4,but with the hotcam you would probably start gaining on the top end of the track so you would end up running faster than 13.9 and I'd say with a good tune and a converter you would see those times drop alot.
Old Feb 8, 2005 | 01:21 PM
Fast Caddie's Avatar
Re: Track Times
Get some headers first!!! Then a tune, higher stall, and you're looking at low 13s/high 12s easily on a good tire.
Old Feb 8, 2005 | 05:53 PM
ChevyTuffD.A.'s Avatar
Re: Track Times
I ran a 8.76 at about 78.6 mph with the mods in my sig but with 2.73 gears and no tune. U for sure need to get that thing tuned and watch your times plummit.
Old Feb 9, 2005 | 05:08 AM
qukz28's Avatar
Re: Track Times
Right now I am working on getting a set of headers, Laptop, LT1 Edit, and converter. Thanks for the info.
Old Feb 9, 2005 | 04:16 PM
maxboosteric's Avatar
Re: Track Times
I ran a 60' 2.01
1/8 9.0 @ 78
1/4 14.01 @ 99
That was before the tune.
Old Feb 13, 2005 | 06:45 PM
chewbonger93z28's Avatar
Re: Track Times
you deffinatly need a tune because thats what my car runs stock
Old Feb 13, 2005 | 10:27 PM
qukz28's Avatar
Re: Track Times
Yes i know i definately do need a tune.. I had a 95 that ran 8.67 at its best with exaust and gears only.
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
