HELP! pulling aluminum headed engine
Old Jan 31, 2005 | 07:41 PM
klumb15's Avatar
hey guys, i got everything undone on my motor tonight, all i gotta do is strap it down and give it a tug outta the engine bay...BUT WHAT DO I HOOK ONTO??? there is a little half *** eye on the front that it looks like you can't even get a bolt in, and there isn't anything in the back that looks remotely too something i could hook onto to pull the motor...the engine is a vette engine so it has aluminum heads, and my dad is afraid of pullin on the intake cuz that is aluminum and so is the heads, he's afraid its not strong enough..yada yada yada, i think it is becuse what else are you supposed to pull on??? i have no idea on what do use to pull this thing out, somebody help me out!!!
Old Jan 31, 2005 | 09:14 PM
89385formula's Avatar
Re: HELP! pulling aluminum headed engine
Did you pull the accessories off the engine? If so, I may be wrong but I just use the accessory mounting holes with the bolt going in the head, and through the chain. I have used this method everytime, and have never had a problem, even w/ aluminum heads. I hope that helps.
Old Jan 31, 2005 | 09:15 PM
klumb15's Avatar
yea all the accessories are completely off....so you think that will be alright or should i use a hole on the block itself?
Old Jan 31, 2005 | 09:25 PM
transxtreme's Avatar
There should be the two hooks on the manifold when you remove the upper plenum and runners. If not, Do the bolt through the head method. It will be fine.
Old Jan 31, 2005 | 10:12 PM
xpndbl3's Avatar
i'd use accessory holes as well. make sure that you put them on the inner most holes, otherwise your valve covers might get a little dent in them. I found that out the hard way one night when i was tired and not looking.
Old Feb 1, 2005 | 06:59 AM
95redvert's Avatar
I have used the bolts and chain method everytime I have pulled my motor. You don't need a long chain, just long enough to reach one corner of the motor to the other and have a little slack. Then out she comes.
Old Feb 1, 2005 | 12:09 PM
Tru2Chevy's Avatar
I dropped my aluminum headed motor into my car using grade 8 bolts threaded into the intake bolts on the heads, didn't have any issues.
- Justin
*Emilia*
May 13, 2015 09:05 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
formula218
Dec 2, 2014 04:27 PM
thenewkid
Nov 27, 2014 09:41 AM
