draglite backspacing
Old Jan 31, 2005 | 12:52 AM
Firebird355's Avatar
What backspacing and tire size are you guys running? I was thinking like maybe a 15x8 and a 26x11.5??? What size backspacing would i need? What is everyone else running for wheel and tire size (draglite, prostar...etc.)
Old Jan 31, 2005 | 10:34 AM
amean94ta's Avatar
Re: draglite backspacing
5.5-6.5 depends on how wide of a tire. on a 10 inch rim use the 6.5. if not use the 5.5 on a 8 inch rim
Old Jan 31, 2005 | 01:34 PM
The 5.5" is correct for the 15x8". You need a 7.5" BS on a 15x10, or your tire will be outside the fender.
This is a 28x10.5-15W on a 15x10 Pro-Star, with a 7.5" BS:
http://cjcfo.fbody.com/members/injun.../DCP03650a.jpg
http://cjcfo.fbody.com/members/injun.../DCP03453a.jpg
Also, click on "Trailer Queen...." in the signature.
I also think that most manufacturers recommend a 10" wide wheel with a 26x11.5-15.
Old Jan 31, 2005 | 02:10 PM
amean94ta's Avatar
yeah i was just saying what you told me sorry my mistake
Old Jan 31, 2005 | 08:56 PM
thanks alot, i heard you had to do some modifications to fit a 28 inch tire? how tall and wide of a tire can you fit under these cars?
edit- without rubbing on the street....
Old Jan 31, 2005 | 11:06 PM
I started with 28x11.5-15 QTP's. The inner fenders had already been hammered for 315 DR's on 17x11's. All I had to do to fit the QTP's was move the axle back about 1/4" to eliminate some rubbing at the front edge of the wheel opening when trap speed went over 120-125MPH.
When I went to the ET Drags, even though they are listed as 28.1" vs 28.0" for the QTP's, I ended up taking about 1-1/2" off the leading edge of the rubber bumper cover. I've had it on dyno rollers at the equivalent of 130MPH, but I'm still not sure if I'll get into problems with tire growth above that. The 15"W" is also a lot wider, so it took yet another round of whacking with the BFH.
Old Feb 2, 2005 | 03:26 PM
EVERESTZ28's Avatar
is this the same for a 94 Z28?
i want to buy rims and slicks, but i don't know backspacing or if a 10" will fit
Old Feb 2, 2005 | 11:16 PM
The wheel info listed above is valid for 93-97 F-Bodys. The offset info is valid for 98 and newer, but the differerent brake calipers on the LS1 cars may be a problem - I never had one of them so I don't know.
As far as the tires, a buddy of mine with a 30th SS convertible had similar issues with hitting the edges of the wheel opening when he put the same 28x10.5-15W's on his car. He eventually went to a 29.5x11.5-15 and it took major body work to the fenders and the internal fender liners.
sssalah
Feb 13, 2003 11:49 AM
jkbadz28
Oct 2, 2002 08:58 PM
jasycZ28
Classic Engine Tech
Sep 29, 2002 04:58 PM
JoshGuitar
Jul 23, 2002 06:20 PM
Jim S. '95 Z28
Jul 19, 2002 09:47 AM
