Good mechanic in PA
Good mechanic in PA
Hey guys and gals, I need a good mechanic for my Z28 in PA roughly around the poconos area.I might have a blown head gasket and a couple other little problems . Need help please.
I 've heard about rapid motors and they sound like they are good just checking if there are any other shops or mechanics I can be refer too.
94 Z28 A4 T-tops
Moroso CAI
1LE elbow
BMR strut tower brace
Carsound hi flow cat
Magnaflow cat back
I 've heard about rapid motors and they sound like they are good just checking if there are any other shops or mechanics I can be refer too.94 Z28 A4 T-tops
Moroso CAI
1LE elbow
Magnaflow cat back
Re: Good mechanic in PA
Originally Posted by Dee94Z28
Hey mikey, thanks when is the best time to give you a call? Also RBE17 thank you for your reply. Also I was thinking about lt4 hot cam kit?
94 Z28 A4 T-tops
Moroso CAI
1LE elbow
Magnaflow cat back
Moroso CAI
1LE elbow
Magnaflow cat back
Go here - http://performanceworks1.com/
We are located in Northampton PA, not far from Bushkill.
Hey blackdog thank you for your reply, nice Z28 in a couple weeks when I am on vacation I will try to get the car checked out so I know what direction to take with the engine and the trans because the car has over 113K. The car run strong but if I have a blown head gasket Is it worth just fixing the gasket or put alittle work into the engine . It was once a daily driver until I brought a second car. So now it will only come out in the spring and summer. I will like to beef up the performance alittle.
Any feed back with suggestion is highly welcome thank you
Send me a private email for more info if you like.
Fbodfather
25
Jun 21, 2002 04:12 PM
