will auto drag 3's with 4.5 b.s fit
Old Jan 23, 2005 | 04:43 PM
amean94ta's Avatar
and if so will they stick out or hide in
Old Jan 23, 2005 | 10:24 PM
Re: will auto drag 3's with 4.5 b.s fit
Assuming "b.s." = backspace - What width are the wheels? Can't answer the question without that info.
If its a 15x8 wheel, you need a 5.5" BS to keep the tire inside the fender line. For a 15x10" wheel, you need a 7.5" BS.
Old Jan 23, 2005 | 10:41 PM
amean94ta's Avatar
yeah its a 15x8 how bad would it be these are my friends and real cheap
Old Jan 23, 2005 | 11:30 PM
The tire will be about 1" outside the rear fender.
Old Jan 24, 2005 | 12:54 AM
amean94ta's Avatar
boy thats not gonna work huh its lowred and the slicks on them are 28 tall
Old Jan 24, 2005 | 08:45 AM
This is a 15x10 7.5BS with a 28" ET Drag. A 15x8 5.5BS would sit in exactly the same place, relative to the outer fender. A 4.5" BS would move the tire out 1".
http://cjcfo.fbody.com/members/injun.../DCP03453a.jpg
Old Jan 24, 2005 | 08:53 AM
amean94ta's Avatar
can you get pro-stars in a 15x10 w/7.5 bs and are there any inner fender mods needed
Old Jan 24, 2005 | 03:22 PM
Yes.... Pro-Stars are available in 15x10 7.5" BS... that's what I run. I had already hammered my inner fenders for 315/35-17 BFG drag radials, on 17x11 ZR1 replicas, so when I had the QTP 28x11.5-15's on there, I didn't have to do any more hammering. When I went to the ET Drag 28x10.5-15W's I had to hammer a lot more.
You need to grind the fins off the corner of the brake calipers.
What actual diameter are the 28's you are looking at? When you get to 28.0" you will have problems with the edges of the fender openings.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Moshbmx1
Jan 20, 2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
