nitrous bottle brackets
Old Jan 22, 2005 | 05:06 PM
kandied91z's Avatar
anyone have custom brackets, something other then the typical plastic versions which came with my NOS ones would be nice. i'm trying to find some quick disconnect versions as well, maybe something in billet but doesn't have to be. tried searching and came up with 110 pages going through half with nothing there.
any suggestions or ideas on aftermarket brackets?
Old Jan 22, 2005 | 05:50 PM
Dean77's Avatar
Re: nitrous bottle brackets
Maybe something like this.....
http://www.speedshop.org/store/scrip...p?idproduct=54
Dean
Old Jan 22, 2005 | 05:53 PM
kandied91z's Avatar
yes something similar to that, i would need the quick release more up towards the top of the bottle though... wouldn't necesssarily have to have a quick release but an easier meathod then the standard bolt and nut deal would be nice.
Old Jan 22, 2005 | 11:51 PM
NOS makes an aluminum quick release bracket. It a split band, about 1.25" wide, with a bolt and a large plastic **** on one side and a ball-pin on the other side. Makes it a lot easier to swap out bottles than the standard NOS steel band with a single (barely long enough) bolt on one side.
Old Jan 23, 2005 | 02:33 PM
kandied91z's Avatar
thanks, i'll look for it...
if anyone knows of any others please post.
Old Jan 25, 2005 | 11:04 AM
"White Knight"'s Avatar
http://www.speedshop.org/store/scri...sp?idproduct=54
will that pass track inspection with those pins? How are they held in? I like that set-up though.
Old Jan 25, 2005 | 01:04 PM
96Z28SS's Avatar
I used the dynotune aluminum bottle brackets and they passed tech no problem. The bottle was empty and i wasn't running NOS at the time but it still passed tech.
Old Jan 25, 2005 | 01:31 PM
joeZ96's Avatar
Fred - Do you know if the NOS quick release bracket mounting holes are the same width/location as the regular NOS black plastic brackets that come with the kits? I'd really like to try the quick release brackets out, but I'd hate to have to drill new mounting holes.
Joe
Old Jan 25, 2005 | 02:41 PM
The 10# bottle brackets that came with my ancient (~1994) NOS 5176 kit have two bolt holes on 5.25" centers. The newer NOS aluminum bottle brackets measure 4.75" center-to-center. The bracket holes look like they could be slotted to allow you to use the old mounting locations, if yours are 5.25" on center. It will be tight getting the bolts heads against the sides of the bracket, but I think it can be done.
I checked the width of the bracket, and they are a full 2" wide aluminum, with rubber liners over the full face of the inside of the strap, to prevent bottle scratches.
Old Jan 25, 2005 | 04:31 PM
kandied91z's Avatar
good info.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
War Engine
Sep 18, 2015 07:28 PM
