LS6 springs w/ aftermarket cam???
Old Jan 21, 2005 | 09:01 AM
mikem94Z's Avatar
Some people say the LS6 spring should not be used with a cam with more than .550 lift,some people say .570.Which is it?
I plan on using a cam with .566 lift.
LS6 spring safe or not?
Old Jan 21, 2005 | 10:47 AM
teke184's Avatar
Re: LS6 springs w/ aftermarket cam???
depends on the year springs they are.
seems like i remember the first year or 2 of the LS6 they were only rated to .550"
but after that they are .570"
why not just get some CC918 springs good for .600"
Old Jan 21, 2005 | 01:56 PM
SSCamaro99_3's Avatar
I would only think about using the LS6 springs with the following cams:
LS6 cam
LS1 Hotcam
ASA Hotcam - even here I would be thinking about 918's.
Old Jan 21, 2005 | 03:43 PM
mikem94Z's Avatar
These are free springs from a friends 03 Z06. It's a lack of money issue?
tight budget these days.
Also I found out the ASA cam is rated at .570 lift and GM recommends using 02 and newer LS6 springs with that cam.
Thanks guys.
Old Jan 21, 2005 | 04:32 PM
LS1 Hotcam 218/228 .525/.525 112 lsa
ASA Hotcam 226/236 .525/.525 110 lsa
ASA Grand Am Cam 239/251 .570/.570 106 lsa
The last two can be easily confused.
A set of 918's is only about $150-175. Maybe better, I haven't priced them in awhile.
Old Jan 22, 2005 | 10:07 PM
Black98's Avatar
I would use the Comp 918's or the Manely NexTek Springs.
hotrodyou1
Dec 20, 2014 10:05 PM
cmdeshon
Dec 12, 2014 10:51 PM
Noenav
Dec 6, 2014 07:35 PM
chuyz28
Nov 25, 2014 11:14 PM
