Would it hurt to...
Old Jan 12, 2005 | 11:40 AM
The Cartel's Avatar
Would it hurt to...
Run n20 on my 11 to 1 355 forged piston, with GTP stage2 heads, custom comp cam cut on a 111 LSA? I have 30lb svo's and I'll just be spraying every so often about 4 times a year max. I just want it if I need it. You know, to shut someone up or whatever. I know it is a little tight on the lsa but I was thinking a wet kit and just maybe a 100 shot or so.... opinions please..
Jason
Old Jan 12, 2005 | 12:37 PM
ford's Avatar
Re: Would it hurt to...
Nitrous loves higher compression
And dont worry about the LSA, my cam is on a 111lsa as well and i have it jetted for 150
Old Jan 12, 2005 | 02:41 PM
The Cartel's Avatar
Yea that's all I was worried about is the tight LSA. Thanks! Sprayin 150 then. Do you feel the wet kit is the way to go?
TIA Jason
Old Jan 12, 2005 | 04:02 PM
captaindbol's Avatar
Nothing to worry about. BTW, the cam in my truck is a 106 LSA installed at 103.5. See signature for times and info.
Old Jan 12, 2005 | 06:20 PM
12Second3rdgen's Avatar
Thats fine, that really isnt that tight of an LSA. I know people running on a 104-108LSA, just means its a less efficient nitrous motor.
Old Jan 12, 2005 | 06:38 PM
The Cartel's Avatar
thanks guys, What's the best for me wet or dry? pro's an cons? new to the n2o...
Jason
Old Jan 12, 2005 | 08:13 PM
Z284thgen's Avatar
WET with a nozzel get that kit from 96camaross your best bet
Old Jan 12, 2005 | 09:56 PM
Dave69Z's Avatar
Definitely get a wet kit.
Hey Jeff, what's up?
Dave
Old Jan 13, 2005 | 07:44 AM
Z284thgen's Avatar
nadda and you
still working to save that $$$$ up for some parts you know of any good deals on any
Old Jan 13, 2005 | 10:48 AM
I've got some parts lying around. pm me
Old Jan 13, 2005 | 11:19 AM
The Cartel's Avatar
whad up jeff.. you got the TNT kit on yet?
captin sending you a pm now...
Old Jan 13, 2005 | 07:09 PM
Z284thgen's Avatar
http://www.myonlineimages.com/Member...es/jetting.jpg
Old Jan 13, 2005 | 07:12 PM
The Cartel's Avatar
schweet... to bad that plate is purple
Noct
May 26, 2016 10:26 AM
Cam's maro
Aug 11, 2015 07:45 AM
colts0455
Jul 8, 2015 12:21 AM
jdelaprida
Jul 4, 2015 03:02 AM
Desolate_Flux
Aug 18, 2002 01:06 AM
