Quick help with gauges
Old Jan 5, 2005 | 09:45 PM
Camabird's Avatar
I bought reverse glow gauges and I got the dash apart fine but I can't get the clear plastic cover off of the gauges. It almost looks as if it is glued on. I have a '99 V6 by the way, help please
Old Jan 5, 2005 | 10:43 PM
Z95m6's Avatar
Re: Quick help with gauges
I maybe wrong but i'm pretty sure its just like a TA's cluster in which case you just remove the bolts that hold it on.
Old Jan 5, 2005 | 11:24 PM
Camabird's Avatar
Nope, there's no bolts holding it in. I got em on, turns out the plastic pieve is glued on but the part that it's glued onto snaps onto the gauges cluster whereas I thought it was glued to the gauges cluster.
Old Jan 7, 2005 | 07:12 PM
camaro 22's Avatar
You have to pull the gauges all the way out. The clear plastin IS glued to the black plastic. In order to get in there, you have to pull the cluster all the way out and you'll see little tabs at the bottom that you have to push in to open the cluster.
KYWes
Jun 14, 2022 06:52 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
