How hard is it to install white face gauges?
Old Dec 31, 2004 | 09:04 AM
91 Camaro RS's Avatar
I saw this on eBay and it looks much better than the stockers.
It has an inverter to make the gauges lightup with those colors.
Old Dec 31, 2004 | 11:59 AM
TraceZ's Avatar
Re: How hard is it to install white face gauges?
That depends. The hard part is removing the needles and getting them back on in the correct places.
I say it depends because some kits dont require you to remove the needles. If the hole in the center of the dial is large enough for the entire needle to fit, then it is a piece of cake.
If you have to remove the needles it gets a bit more tricky. I'd recommend taking a picture of each needle close up with the ignition on. Use the picture for reference when reinstalling them.
To do my speedometer, I had a friend drive in front of me at 60 mph. I followed him and had a buddy reach over and steer while I put the needle back on at exactly 60. It is right-on!
Old Dec 31, 2004 | 12:04 PM
Aiight, thanks for the info. According to the auction ( http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT ), I don't need to remove the needles.
One question for you about yours. When you did it, is yours just the paper, or does yours have the lights and inverter like the one I'm looking at? Can you post a big picture of your gauges (even if yours doesn't have the extra lights)? Thanks.
Old Jan 5, 2005 | 09:37 PM
RansZ28's Avatar
Take your time - I did remove the needles and had no problem doing it.
Old Jan 5, 2005 | 10:00 PM
stereomandan's Avatar
I don't know why, but I cracked up reading that. Just picturing it.
Dan
Old Jan 5, 2005 | 10:19 PM
I screwed up really bad. I bought the gauges and the speedo of the gauges is 140mph, the speedo on my car is 110mph. So now I have to buy the gauges that are 110mph (which are more expensive because they are harder to find). *sigh*
Old Jan 5, 2005 | 10:31 PM
unvc92camarors's Avatar
think they have some here
thirdgenresource.com
Old Jan 10, 2005 | 10:47 PM
FLeXNuTZ's Avatar
Will someone please take a pic of their gauges for me? I have a stock idle and a M6. I really screwed mine up. This pic is sitting in the garage on jack stands with the motor off
http://img.photobucket.com/albums/v2...20/Gauges1.jpg
99TransAmWS6
Feb 12, 2015 07:23 PM
ANDYZ28
Dec 29, 2014 09:13 PM
slothgrant
Aug 22, 2002 03:01 PM
ollie-99
Jun 20, 2002 08:55 AM
