Do you need a Bypass Valve is you have a BOV??
Old Dec 29, 2004 | 11:45 PM
Muskys SS's Avatar
I'm going to be running a vortech strim and was wondering if I should get a bypass valve or a blow off valve. I heard that blow off valves release more air.
Old Dec 30, 2004 | 07:22 AM
MEAN LT1's Avatar
Re: Do you need a Bypass Valve is you have a BOV??
I think what your asking is"Do you need a bypass valve if you have a bov.?"
The answer is no b/c there essentially the same thing. But alot of people with blowere applications are running a bov with success.
Old Dec 30, 2004 | 09:53 AM
Muskys SS's Avatar
Yes that's what I was asking. thanx
Old Dec 31, 2004 | 09:24 PM
CoUnTryMuZiCZ28's Avatar
If your running alot of boost a bypass valve would be almost necessary. A blow off valve releases air when there is a sudden pressure increase (letting off the gas under boost). A supercharger is ALWAYS making pressure before the TB blades. If there isnt something to release the pressure you can kiss the bearings on your SC good bye. A bypass valve is open when your engine is under vacume (idle and cruising) a blow off valve is closed.
Old Jan 6, 2005 | 04:08 PM
MEAN LT1's Avatar
Not trying to be an a$$ or anything but are you sure?. A bov is vacume operated just like a bypass. When your out of boost and seeing vacume a bov is open until until you get on it and start seeing boost. It then closes the valve when in boost and opens back up when out. What am I missing here?.
Old Jan 6, 2005 | 05:59 PM
are you sure? Im almost positive a BOV is closed except when there is a sudden increase in boost. Turbos dont make boost at idle..
Old Jan 6, 2005 | 06:25 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Bypass valve- Supercharger application. Open under vacuum/cruising to 'bypass' air from the supercharger. Closed under boost.
BOV- Turbo application. Closed under vacuum/cruising. Only opens after boost is made and throttle closes.
Old Jan 8, 2005 | 04:21 PM
NtenseZ28's Avatar
My S-Trim kit came with a by-pass valve....no need for a BOV.
Here's the Mondo if you don't have it.
http://www.vortechsuperchargers.com/...s/aircomp.html
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
