3 cam option- which 1 to order?
Old Dec 29, 2004 | 09:27 PM
blown3rdgen's Avatar
I talked to the tech dept at comp cams, crane and cam motion. They recommended the following cams. Which of the 3 would you use?
383cid, 9.1 to 1, procharger "blow-thru" design (6-8#), water/meth inj, afr195s, 700r4 with 2800 stall, 3.89 gears, 3300lbs with driver, max rpm 6600
--current cam: xtreme energy 236/242 .525/.547 112lsa--
Comp- 236/248 .525/.547 113lsa
crane- 230/238 .539/.558 112lsa
Cam motion- 231/240 .541/.565 112lsa
So which would you choose? I am considering a cam change, because the motor is out of the car and am just looking for something "ideal" for my set-up.
Old Dec 30, 2004 | 09:50 AM
rskrause's Avatar
Re: 3 cam option- which 1 to order?
None of the above. Why limit yourself to those choices?
Rich
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Jan 23, 2015 01:13 PM
Elcojoe
Nov 17, 2014 10:27 PM
