performance rotors for ls1
Old Dec 25, 2004 | 07:38 PM
cralarcon_IROCZ's Avatar
I was thinking on swopping my factory rotors for some cross drilled or slotted ones. What i had in mind is putting some brembo cross drilled rotors. what do you guys think? if you have suggestions on rotors that are better or where i can get them for a cheap price let me know. thanks guys
Old Dec 25, 2004 | 08:33 PM
5.0THIS's Avatar
Re: performance rotors for ls1
Get the slotted/drilled only if you're interested in their looks. They will not improve braking performance at all. If anything they may hurt brake performance.
Old Jan 4, 2005 | 05:43 PM
slp223's Avatar
i got bear earidspeeds two peice if they warp or wear our you can replace the the friction part with out having to get new hats
Old Jan 4, 2005 | 07:30 PM
DiabloGT's Avatar
did you see any increase in braking?
Old Jan 5, 2005 | 06:35 AM
RE AND CHERYL's Avatar
Your not gonig to see increased braking from slottd or cross drilled rotors. As you are actually decreasing the swept area your braking should actually go down. The benifit comes under repeated hard braking when the brakes get real hot. The slotted or crossdrilled rotors will cool faster and provide increased braking in that instance.
Personally I would stay away from all but the highest quality drilled rotors. Almost every one I've ever seen eventually gets cracks around the holes. I use Power Slot rotors and they look great and didn't cost too much.
Old Jan 5, 2005 | 08:37 AM
slp223's Avatar
i did them the same time i did my ls1 swap so yes i felt better braking. but i have no idea if it had anyanything to do with the rotors.
HarleyZ28
Oct 5, 2015 06:23 AM
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
