Sup-Frame Install
Old Dec 21, 2004 | 07:23 AM
SpeedDemon02SS's Avatar
Sup-Frame Install
How big are the bolts to that hold the front ends of the rear lower controll arms? And is it ok to remove those bolts without supporting the controll arms?
Old Dec 21, 2004 | 10:13 AM
Stoopalini's Avatar
Re: Sup-Frame Install
I don't remember the size of the bolts (3/4" - 7/8" or something) but you can remove them without supporting the LCA. Just put jack stands under the rear diff and do one side at a time. If you remove both LCAs it can be difficult to get the rear lined up again when reinstalling them.
Thomas.
Old Dec 21, 2004 | 05:57 PM
laiky's Avatar
putting jack stands under the rear and unbolting the control arms is a BAD idea!! you must support the chassis with the stands, then use a jack to support the rear while removing the arms
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
