Air fuel ratio
Old Dec 19, 2004 | 10:01 PM
Schurters LT1's Avatar
Air fuel ratio
Where is everyone keeping there are with there set up....I have read that 12.1 is a safe rario..but why do some people drop there are to 11.1 ...
Old Dec 19, 2004 | 10:22 PM
Birdie2000's Avatar
Re: Air fuel ratio
From what I've always heard 11.5-12:1 is the typical recommendation. Some people might run it rich to be on the safe side just for peace of mind.
Old Dec 20, 2004 | 04:58 PM
arnie's Avatar
Re: Air fuel ratio
Good question. No reason to, IMO. Fuel makes for an inefficient mixture cooling medium, and combustion doesn't ignite/burn all the fuel, at the ratio, if those were the reasons/excuses of some.
Old Dec 20, 2004 | 08:10 PM
Alvin@pcmforless.com's Avatar
Re: Air fuel ratio
12.1 is plenty safe.. your looking for no knock.. thats the issue
Old Dec 20, 2004 | 09:59 PM
wingnut's Avatar
Re: Air fuel ratio
Using DFI 7 with wideband control. Target a/f Ratios
Pump Gas (93)
IDL 14.0:1
Cruise 14.7:1
5" Vac 13.5:1
0"vac - 5# 12.5:1
6# - 9# 11.8:1
10# - 20# 11.5:1
Total timming at boost 17 deg
C-12
IDL 14.0:1
Cruise 15.0:1
5" Vac 14.0:1
0"vac - 5# 13.0:1
6# - 9# 12.5:1
10# - 20# 12.0:1
Total timming at boost 24deg
These number gave best dyno results with 355 and t-88, .96a/r and 4" down-pipe.
But not all combos react the same way
Preacher Bryan
Old Dec 20, 2004 | 11:03 PM
Re: Air fuel ratio
Pump Gas (93)
IDL 14.0:1
Cruise 14.7:1
5" Vac 13.5:1
0"vac - 5# 12.5:1
6# - 9# 11.8:1
10# - 20# 11.5:1
C-12
IDL 14.0:1
Cruise 15.0:1
5" Vac 14.0:1
0"vac - 5# 13.0:1
6# - 9# 12.5:1
10# - 20# 12.0:1
Preacher Bryan
What is your combo.....would like to no....doing a 355 aswell
Old Dec 20, 2004 | 11:19 PM
Re: Air fuel ratio
some high heat inneffecent setups like a bit richer setups like the eatons.. most lightnings and cobras start heading the other way when your leaner than late 11's or so.
Old Dec 21, 2004 | 09:05 AM
wingnut's Avatar
Re: Air fuel ratio
355 LT1, DFI 7 with wideband control, h-beam, forged crank, J&E pistons -24cc, all studs, cometic head gaskets, ported LT1 manifold, 58mmTB, C&C LT1 heads (flow 284 @.600 on intake, 233 @ .600 on exhaust, open combustion chamber (about 62cc now), 2.02intake 1.60exhaust.
Cam is a custom turbo design based on a 114 lobe seperation and .560/.560 lift (don't know the other #'s on it right now), mondo blow-off valve from Vortec, 44MM wastegate, t-88 turbo with .96a/r modified square flange, top mount like an SVO (over dr valvecover) with about 4" down pipe, big injectors, total eliminator pro fuel system from Aeromotive, #10 out of sump in tank to pump, duel #8 going into fuel rails, duel #6 out to pro regulator, #6 back to tank (over kill on fuel system in case I need it), t-400 with about 400 stall, 4:10 12-bolt and 28" tall tires, lost of tube in the suspension, no p/s, no a/c.
I think that is the basic. never over 16# of boost yet - need bigger injectors. Car is street leagle and all numbers are on pump gas (93) this winter I am going to make a couple dyno runs on c-12 or c-16 and turn the boost up. The car is street legal but I have skinnies on front, ET streets on back with bead locks all the time ( not daily driver ). The t400 took about 150 rwhp from me, but allowed me to stay in boost and only shift twice (I tore up my six speeds) Overkill? Yes. Fun? Yes. Do it again? NO!!! I would buy or build an airplane..... Roll-bar, harness, IHRA rules, (I do not street race), Cool car, light, nice in and out, but for racing and cruising only. Not hard to drive, just limited use.
I built a car for my wife (94 Z-28), simple 42# injectors, 383 from Nu-teck, procharger and 13#'s of boost. Ed Wright got about 500 Hp out of it and almost 20MPG!!! All with ac and everything, fun and easy to drive.
I hope this helps. There are a lot of smart people on this board that helped me out and I can't thank them enough. When it comes down to it though, I like to fly and build airplanes.
Bryan
Old Dec 21, 2004 | 12:51 PM
Willie's Avatar
Re: Air fuel ratio
....most lightnings and cobras start heading the other way when your leaner than late 11's or so.
Agreed. Most L owners like to see 11.8-to-1.
Old Dec 21, 2004 | 02:54 PM
rskrause's Avatar
Re: Air fuel ratio
12-12.5:1.
Rich
Old Dec 21, 2004 | 04:39 PM
Re: Air fuel ratio
Do you allways want 12ish AFR NO mater what power you are making...
Old Dec 21, 2004 | 10:22 PM
SMOKNZ's Avatar
Re: Air fuel ratio
HEy wingnut, any pics? I had a guy send me his pics of a single turbo monted over the valve cover, I reall liked it, and If I could have I'd do twins the same way!
Old Dec 21, 2004 | 10:57 PM
wingnut's Avatar
Re: Air fuel ratio
SMOKNZ, go to http://community.webshots.com/user/turbota
it is my webshots page. I will update the pics Wed. However, there are plenty of good shots there right now. I can also e-mail others to you.
Bryan
Old Dec 22, 2004 | 12:37 AM
5.0THIS's Avatar
Re: Air fuel ratio
Bryan
great looking setup Bryan
Old Dec 22, 2004 | 10:21 AM
SMOKNZ's Avatar
Re: Air fuel ratio
You must have emailed that pic to me a couple months ago when you were building it. Now thats some creative fabrication. Looks awesome!
