Fitting vortec pcm into lt1 opti elimination
Old Dec 16, 2004 | 01:48 AM
Highlander's Avatar
IIRC the vortec trucks use a similar looking pcm, although hardware is different.
Anyone have a pic of a vortec timing cover.. .if it can be adapted the timing cover to our block it would be very simple to eliminate the opti, converting to obd2 and using that pcm...
That pcm uses a CKP and CMP and voila NO MORE OPTI.
Old Dec 16, 2004 | 02:26 AM
tjwong's Avatar
Re: Fitting vortec pcm into lt1 opti elimination
I thought of that as well Chris, but the bolt patterns are different. Not to even mention that you would have to modify the LT1 intake for a distributor because that is where the cam sensor is on a Vortec SBC.
Old Dec 16, 2004 | 07:49 AM
Highlander's Avatar
Nothing that hasn't been done before...
www.lt1intake.com
Check it out...
Injuneer
Dec 15, 2014 09:36 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
thenewkid
Nov 27, 2014 09:41 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
