.040 pistons for 3.875 stroke
Old Dec 10, 2004 | 09:31 PM
Denny McLain's Avatar
Need a little help on 4.040 pistons for a 3.875 stroke crank. I’m having my engine bumped up from a 385 to a 398 over the winter and for some reason the person whom will be doing the balancing and assembly is claiming to be having problems finding pistons. Says there is all kinds of .030 pistons but no shelf .040’s.
The last time I did a 398 it had J&E pistons but don’t have model numbers. Anyone know any off the shelf pistons I can use and have part numbers. Anyone have a better alternative?
Thanks guys!!
Old Dec 10, 2004 | 09:46 PM
rskrause's Avatar
Re: .040 pistons for 3.875 stroke
Thanks guys!!
What coimpression height do you need? In any case, all of the high end pistons are available as "customs" with whatever CH you need for a nominal charge (or in some cases at no extra charge). JE and Diamond are both that way, and others too I imagine.
Rich
Old Dec 10, 2004 | 11:52 PM
1racerdude's Avatar
Call Probe Industries,they can make them if they don't have them on the shelf and any way you want them.
Old Dec 11, 2004 | 07:27 AM
Thanks again. I was in a hurry to go to a X-mas party and forgot to mention I have 6" rods.
How do the Probe pistons rank as to compared to J&E? Don't know anything about them in terms of quality, weight, etc.
Old Dec 11, 2004 | 09:38 AM
1racerdude's Avatar
As good a quality as anyone,and better than most.You can get what you want,they can make anything.I have been using them for 15 yrs or more.
Whatever weight,design,ect. Give them a call.
Old Dec 12, 2004 | 01:31 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
damn i have a set of 4.040 pistons, about 2000 miles on them. custom je's, 1.2125 comp height. but i am running a 5.85" rod. any interest? not sure they would work on your setup.
Old Dec 12, 2004 | 07:27 PM
rskrause's Avatar
Well, you need a CH of 1.0625" assuming zero deck and a 9.00" deck height. There are lots of 1.050" 40 over pistons out there and you could use them. A 1.050" piston would require taking .0125" off a 9.000" deck. Of course, you may not need to be at zero deck anyway depending on gasket choice and desired quench.
Rich
Old Dec 13, 2004 | 08:51 AM
racer7088's Avatar
Thumbs up Re: .040 pistons for 3.875 stroke
Denny, You will probably have to get a custom piston as I run these all the time and there are no shelf pistons since no one regularly races that combination.
Old Dec 13, 2004 | 09:20 AM
Again..... I thank everyone for your help.
Now the question is: If I need custom pistons and all my block needs is honed.... Should I do maybe .041 or .042 to compensate for the honing??
Cost the same right!
Old Dec 13, 2004 | 10:13 PM
racer7088's Avatar
Yes,
It's done all the time!
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
