Where to run an electric cutout wire?!
Old Dec 3, 2004 | 06:57 PM
Klypto's Avatar
i searched the site... couldnt find it.....
where is the best place to run it, and ive seen ppl say the exhaust melting their wires... how to avoid that?
thanks
cory
Old Dec 3, 2004 | 11:23 PM
PipesTA's Avatar
Re: Where to run an electric cutout wire?!
Where is your cutout located? Over the axle or in the primary pipe? I would just say pull the seats and carpet, drill a small hole in the floor run it through that and silicone the hole so you won't have any leaks.
Old Dec 4, 2004 | 03:59 PM
D James's Avatar
I don't like the ideaa of drilling a hole through the floorboard, so I used a razor blade and cut a slot through the little rubber drain hole found under each seat, you can't miss them, then just pull up the carpeting a little and slide it to where you want to run the switch. I have the DMH and hte included switch actually fit right into the lightbulb socket holder in the ashtray, no kind of work for me at all.
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
Jazsun
Dec 29, 2014 12:14 PM
lbrowne
Nov 13, 2011 04:25 PM
