i broke a tranny mount
Old Nov 27, 2004 | 03:54 AM
Ninety3Z's Avatar
i broke my tranny mount tonight while cruisin with my friends SS...we both took off at the light and my car goes BOOM.... 3rd one so far.
how much am i lookin at? its been a while.
Old Nov 27, 2004 | 03:55 AM
Ninety3Z's Avatar
Re: i broke a tranny mount
its a 93z with an A4
Old Nov 27, 2004 | 04:03 AM
WestCoast96Z28's Avatar
The GM part number is 22201140. I ordered one from GM Parts Direct a few weeks ago...cost a little over $30.
Old Nov 27, 2004 | 04:06 AM
Ninety3Z's Avatar
i take it you installed it yourself...
was it hard?
how much time?
procedure?
ONLY if you have time, but will be appreciated.
Old Nov 27, 2004 | 07:36 AM
94zgreenmachine's Avatar
Get the poly mount from summit. It is an energy suspension mount and it has a little more vibration with the a4 . I only notice the vibration when I go around 75MPH or higher, but I also have the loudmouth exhaust so I really don't care much about noise, obviously!!
Easy install though. Jack the back side of the car, slide under. Support it of course. Jack up under the tranny to lift it off the crossmember slighty. Remove, I believe (its been awhile for me also) two bolts from the tranny and the single bolt to the crossmember and insert the Poly mount. It comes with hardware. I think it took me more time to get the car supported than it did to actually change the part. By far the easiest thing to swap on these cars.
Old Nov 27, 2004 | 08:46 AM
MentalCaseOne's Avatar
Get the energy suspension Tranny mount and be done with it.
I cant even remember when I bolted to my car. Totally Unbreakable for my application.
Marvin
Old Nov 27, 2004 | 01:25 PM
93LT1355's Avatar
I totally agree with everyone else. Get the energy suspension mount. I broke my tranny mount at the track about 3 months ago and ever since I changed to the energy suspension mount, I have had not problems.
Old Nov 27, 2004 | 01:30 PM
Ninety3Z's Avatar
i was at autozone.com a lil while ago and it looks like there are a buncha different energy suspension mounts. ES black ES yellow...
is it just the BLACK one? im planning to do this tonight when i get off of work.
Old Nov 27, 2004 | 02:34 PM
Ninety3Z's Avatar
k i got the stock one...:-/ if i break one every 3 months like he said maybe id go with the ES...but for now im cool.
thanks for all the help, anytime i need help with my car, i just come here and get the answers....i love this board.
-steve.
Old Nov 28, 2004 | 07:53 AM
curly's Avatar
I had the ES on my car and I will never put one on again. I put a LS1 tranny mount on the car which fixed the "teeth rattling" experience . Just my personal experience.....
Old Nov 28, 2004 | 10:11 AM
The A4 cars will vibrate more . Especially thru the console. BUt I remember almost having to change my drawers as soon as the tranny mount broke while I romped on it. I thought something was coming thru the tranny tunnel!
Old Nov 28, 2004 | 12:12 PM
Ninety3Z's Avatar
same deal. the first time i broke it, i thought i killed my car. this last time i was like "not again!"
replaced it this morning...took an hour due to lookin for the right sockets to use with my air ratchet. super easy though. the old one was destroyed.
Old Nov 29, 2004 | 02:21 AM
Z95m6's Avatar
I thought i remember reading on the board that you can wrap a hose clamp around the stock tranny mount and tighten it up. It will help keep it from coming apart and it will still be soft enough to dampen vibration.
Old Nov 30, 2004 | 10:06 PM
Capn Pete's Avatar
You're right, the Energy Suspension ones DO cause a lot of vibration (I put one in my car, and my buddy put one in his '97 Z28 M6). I'm considering putting back my stock LS1 mount just to get rid of the vibration. Also the stock LS1 mount is actually much more solid looking than the stock LT1 mount. I think it's probably a good compromise of strength with no vibration. I'd probably recommend the LS1 tranny mount to anyone that wants something better than the LT1 mount without going so far as getting the ES mount.
dylan1303
Aug 12, 2015 02:00 AM
SergheiS
Jul 5, 2015 03:27 AM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
dylan1303
May 22, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
