who has Fastburn heads?
Old Nov 26, 2004 | 10:48 AM
S. Holley's Avatar
I am thinking about using fast burns on my 77 L-48 350... these are low compression motors that hardly push any AIR.... If you have used these heads on your factory 350 and have any dyno numbers please report them with other mods....
If I keep m orginal l-48 block I am looking for 300-325 rwhp so I will need to make a 375-400Hp 350. This way I can keep up with modern day cars and run low 13s
Old Nov 26, 2004 | 02:38 PM
Rice Killer87's Avatar
Re: who has Fastburn heads?
with those heads and a mild cam,375-400 hp wouldnt be that hard.
if ur lookin for some more compression,u might be able to use a thinner head gasket,or mill the heads some.
Old Nov 26, 2004 | 08:30 PM
MY91Y84's Avatar
the Fastburns use the same intake port and chamber shape as the LT4 heads except there conventional coolant flow and have a 64cc chamber rather then the 54.4 of the LT4...they even use the same sodium filled intake valves...LT4's made 330HP@5,800 and 340lb ft@4,400...if you mill the decks for a smaller chamber remember to mill the intake face aswell...
when i had a stock LT4 in my GTA iit trapped 109...that was with long tube headers and dual exhaust with a 650 dbl pumper carb...remember the LT4 ss camaros trapped 107
Old Nov 26, 2004 | 09:34 PM
S. Holley's Avatar
SDPC says the have a 62cc chamber? I actually thought they were smaller than 62cc... I thought they were 58cc
I guess nothing a little machine work and head gaskets couldn't fix.
Do either of you guys have dyno numbers?
Old Nov 28, 2004 | 06:58 AM
hardcoresoldier's Avatar
i have a set...they have 62cc chambers.if you want ill give u a good deal on them.ive never used them,decided to use different heads.
Old Nov 28, 2004 | 11:33 PM
kandied91z's Avatar
320 horse/ 330 torque with miniram III at 9:5:1 roughly 50 more horse/ 70 more torque with superram....and 10:8:1 we'll see after it's tuned and the heads are back from the mil.
Old Nov 29, 2004 | 11:50 AM
S. Holley's Avatar
WOW..not bad... I am still thinking AFR 195...but the chambers are 68cc.. if the chambers were smaller I would go with them w/o thinking becasue the AFR flow a lil better than the Fastburns.
Old Nov 29, 2004 | 04:34 PM
kandied91z's Avatar
yes they do.
Old Nov 29, 2004 | 05:17 PM
S. Holley's Avatar
Yes they do what?
Offer the 195cc AFR with 62cc chambers?
Old Nov 30, 2004 | 02:01 AM
MY91Y84's Avatar
its not concrete, but ive beat a lightning that trapped 113 was door to door with a vette that trapped 115 and lost a carlenght to a H/C LS1 that trapped 119...going by that and my weight of 3400 pounds im roughly 360 to the ground..with a 224/230 cam and stock Lt4 heads
the fastburns flow 242@.500 and the AFR 195's flow 262...
Old Nov 30, 2004 | 03:43 AM
kandied91z's Avatar
Originally Posted by S. Holley
...........I would go with them w/o thinking becasue the AFR flow a lil better than the Fastburns.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
