removing transmission
Old Nov 8, 2004 | 12:10 PM
Nickolbag95z28's Avatar
how hard is it to switch transmissions in a 1969 camaro? can you take the trans right out or do you have to lift the engine too?
Old Nov 8, 2004 | 02:07 PM
will69camaro's Avatar
Re: removing transmission
From my experience the trans just comes right out. I had a super t-10 bolted to a lakewood bellhousing and i just undid 4 bolts on the trans and it came away from the bellhousing. However it was a little harder to get the bellhousing out. Has to undo the motor mounts and put the engine on a hoist and move it forward a little because it was so big. If its a stock bellhousing i'd think it would just come right about without having to move the engine at all.
William
Old Nov 8, 2004 | 11:32 PM
MaxHarvard's Avatar
Manual or auto?
Auto's will come out with no problem... just invest in a good jack and a friend to help guide it in and out.
Old Nov 9, 2004 | 07:45 AM
its an auto. thanks for the help.
Old Nov 15, 2004 | 08:20 PM
olds327's Avatar
to romove a tranny is nothing, just impact out the bolts and bolt the tranny to the motor, and the tranny mount and it should drop out with a little help...
Old Nov 15, 2004 | 10:20 PM
Capn Pete's Avatar
It just depends on if your exhaust will get in the way.............we just swapped the transmission in my Dad's '73, and it was a b!tch to get the TH350 squeezed between the headers (we basically had to lift one side up, slide it over top of that pipe, then lift the other side of the tranny up and in place..................not real difficult, just tedious).
Victor Lamb
Aug 26, 2017 02:52 PM
Apr 16, 2015 09:57 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
