Weird Rear Defroster Problem
Old Nov 8, 2004 | 11:50 AM
Red97LT1's Avatar
Now since it's getting cold and frost is starting to get onto the back glass,I have noticed that the defroster light will go out after about 15-20 secs. Now if it is warm and nothing is on the glass,it works fine????
Old Nov 8, 2004 | 01:59 PM
ehsfootball71's Avatar
Re: Weird Rear Defroster Problem
try putting a 30A fuse in place of the 30A breaker
Old Nov 8, 2004 | 06:23 PM
Red97LT1's Avatar
Ok. I replaced the 30a breaker with a 30a fuse and it still cutoff,just not as soon.But,the breaker was reallyHOTTTTTTT when i removed it. I could feel the heat on the back window when it was on though.
Old Nov 8, 2004 | 07:05 PM
Red97LT1's Avatar
Well,
I got my manual and it told me how to check the grid.Anything below 6 volts was ok and anything around 10 volts means a broken grid. I did it and it found a break in the bottom grid about 1/4 inch long. It's amazing how something that small causes big problems. The short was causing the breaker to get hot and shut off i guess.
Old Nov 10, 2004 | 07:35 PM
Red97LT1's Avatar
Fixed the grid all the volts check out,but the breaker still gets hot.could it be because the windoe doen't have nay frost on it right now?
Old Nov 10, 2004 | 08:23 PM
shoebox's Avatar
The breaker is always going to get some heat in it. Are you saying it still cuts off quickly?
Old Nov 10, 2004 | 08:28 PM
Red97LT1's Avatar
no.Before it would cutoff after about 30 secs.Now it's more like 2-3mins.That's why i thought that it may be cutting off because there is no frost.
Old Nov 10, 2004 | 08:30 PM
shoebox's Avatar
I would retest it on a frosty day.
Old Nov 10, 2004 | 08:50 PM
Red97LT1's Avatar
I hear ya.
jcamaro95lt1
Jan 24, 2015 08:21 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
Britbilly
Jan 7, 2015 08:49 PM
siguy
Nov 27, 2014 10:07 AM
