Speedo question with new rims
Old Nov 7, 2004 | 10:43 PM
mr_muff's Avatar
ok im just curious as to wether im going faster or slower now. old rims where 275/40/17, and i just got some 275/40/18's. like will my odometer rack up the km/s or will they go up slower.
TIA
Old Nov 7, 2004 | 11:53 PM
GreenDemon's Avatar
Re: Speedo question with new rims
Indicated speed should be about 6% less than actual speed.
Old Nov 8, 2004 | 12:02 AM
My calculator says you went from a 25.66" tire to a 26.66" tire, and the speedo would read 3.9% less than actual speed, and you will be adding only 962kM to the odometer for each 1,000kM you drive.
These number can vary slightly, depending on the exact measurements for the specific tires you chose.... not all manufacturers show identical dimensions for a given size tire.
Old Nov 8, 2004 | 01:24 AM
mr_muff's Avatar
thank you very much good sirs
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
blac94Z
Feb 10, 2015 11:02 AM
Kato
Jan 26, 2015 09:21 PM
