Stainless Steel brake line question
Old Oct 27, 2004 | 11:34 PM
95 firechicken's Avatar
I have a 95 Formula that i'm upgrading the front brakes on to some from a 99 my question is which SS lines do I buy ones for a LT1 or for a LS1
Thanks in Advance
Clint Wulfnut@***.net
Old Oct 28, 2004 | 12:13 AM
Z95m6's Avatar
Re: Stainless Steel brake line question
Thanks in Advance
I would use the LS1 lines as they look like they are longer. I reused the stock LS1 lines when i went to the LS1 setup. I personally wouldn't waste my money on the stainless lines. Hell the lines aren't that old. The lines that came with my car were fine.
Old Oct 28, 2004 | 12:24 AM
RobbyRob's Avatar
The SS lines are worth the money. Don't be cheep when it comes to stopping your car. Don't you like it? They are a big improvment over the stock lines..
Old Oct 28, 2004 | 12:32 AM
Z95m6's Avatar
I don't really see it as being cheap. If the stock lines work fine for the LS1 system then i don't see why they wouldn't work for our cars. I would only replace them if the old ones were worn,ripped, or dry rotted. I do love the brakes though they are awesome.
Old Oct 28, 2004 | 12:35 AM
RobbyRob's Avatar
The ss line stop your car soooo much better then the stock lines. It just don't make sence not too....
Old Oct 28, 2004 | 04:21 AM
Hood_Lum's Avatar
Get the LS1 lines.
They stop a whole lot better.
Old Oct 28, 2004 | 09:36 PM
Bud M's Avatar
Use the 98+ lines. The rears are the same for all 4th gens.
Old Jan 17, 2006 | 07:20 AM
kick Z tail out's Avatar
So the Earls Stainless LT1 brake lines I bought won't work when I convert to LS1 brakes?
True?
Old Jan 17, 2006 | 07:40 AM
PLEASE post on the correct forum.... "brake" questions belong on "Suspension, Chassis and Brakes", not on LT1/LT4 Engine Tech".
Moving......
Old Jan 17, 2006 | 08:26 AM
Steve0's Avatar
The stock LS1 lines have a metal "L" shaped section which extends the brake line off of the caliper, then directs it upwards towards the bracket. The majority of the hose is rubber. The LT1 lines are just all rubber and are lacking the "L" shaped section.
Either or will work. The LT1 lines are a bit shorter and you'll probably have to modify your bracket. I bet the section of rubber hose on either stock lines is pretty comparative. That said, any "stretching" of the hose due to brake line pressure is probably pretty similar. I don't think using one stock line or the other is going to make a measurable difference in braking performance.
It seems to me that the purpose of the metal section on the LS1 lines is to just keep the brake lines from rubbing against the caliper and possibly getting damaged. If you want to use LT1 lines and you're concerned about this, wrap the brake line in some small diameter heater hose or something to protect it where it comes in contact with the caliper.
If I was purchasing aftermarket brake lines, I'd just order the LS1 lines and not worry about any length issues.
Jazsun
Dec 29, 2014 12:14 PM
Dec 17, 2014 11:00 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
JTP
Jul 20, 2002 08:24 PM
