Retained Accessory Power
Old Oct 17, 2004 | 02:16 PM
codypher's Avatar
A week ago when i went to start my 94 firebird v6; the battery was dead, after jumping it, and troubleshooting a bit.. i found that my radio would cut off as normal when i opened my door... however as soon as i shut the door.. it would come on again. This goes for the power windows as well.. I found my RAP and the relays seem to be clicking fine, they arnt stuck or anything. Will replacing the module fix the problem? Or is there something else causing the problem? Thanks for any info!!
Old Oct 17, 2004 | 02:58 PM
Dave89IROC's Avatar
Re: Retained Accessory Power
yea, probably the module
where are you located?
Old Oct 17, 2004 | 03:03 PM
codypher's Avatar
I'm in blackwood,nj
Old Oct 17, 2004 | 08:02 PM
JOE96Z28SS's Avatar
RAP is Controlled by the BCM (Body Control Module) Along with a ****load of other functions. When mine went the dome flashed a million times and the Security light stayed on the cool thing is when you get the Service Replacement BCM, it will accept almost any transmitter so finding new ones aren't hard, but you will have to reprogram all of your transmitters. Also, if you get one out of another car, you WILL need to know the PASS KEY Code a New BCM leans it at first start but a used one will not, so you will need to make new keys with the Correct Resistor Pellet,, the BCM is located right behind the Right Side of the Glove box, with three Connectors, two small and one Big
Old Oct 17, 2004 | 09:35 PM
Dave89IROC's Avatar
94's did not have a BCM, They used a RAP module to control the RAP functions
http://shbox.com/1/express_down1.jpg
96 was the first year for BCM's in F-bodys
Old Oct 18, 2004 | 12:23 AM
JOE96Z28SS's Avatar
Ooops, , Did BCM's start with OBDII??? I always owned 96-98's Sorry for the Misinformation
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Heathen1
Jan 2, 2016 04:27 PM
XtremeLt1
Sep 13, 2002 08:50 PM
