Just got MadZ tune, but.....
Old Oct 1, 2004 | 09:45 AM
GR8RIDE_96's Avatar
just recieved my madz28 tune , put it in, went to the track, then my opti went . now my engine light is coming on, used hypertech scanner and it's throwing distributor codes(obvious opti problem) but also, it's now showing "pcm memory"code. what does this code mean??
Old Oct 1, 2004 | 10:36 AM
CColtManM's Avatar
Re: Just got MadZ tune, but.....
I would get a hold of the guys that did your computer. The opti, that might just be its time, or else a newly modified engine was to much for it.
Old Oct 1, 2004 | 10:41 AM
madwolf's Avatar
If it's throwing and opti code, then it is your opti, as for the memory code, I have no idea why you are getting that. Do you have the code number?
Old Oct 1, 2004 | 04:20 PM
GR8RIDE_96's Avatar
code # P0601 from the hypertech powerscan(that's the pcm code)
other codes thrown: P0323, P0332, P0372
Old Oct 1, 2004 | 04:26 PM
madwolf's Avatar
Hmmm....
so it was fine for a while (no codes) then you got this?
Did you try switching to your stock PCM to see if the codes are the same? I am suspecting a bad ground (provided it ran fine before), but if you also notice some driveability problems, then it may be the opti.
Old Oct 2, 2004 | 12:13 AM
GR8RIDE_96's Avatar
the thing is, is that i got the tune, went to the track and was running slower than usual(no engine light was on, so i'm assuming no codes were being thrown). i'm sure it wasn't specifically due to the tune(thinking opti), because my buddy that got the same tune was running 2mph faster in the 1/4(just from the tune), we swapped our computers, and he was running same times and mph with his comp, and i was running the same crap as i was with mine. my car stalled a couple times and had rough idle on and off once i got the tuned comp, and i think that the opti just started going at that time, but nothing had to do w/ the tune. so who knows, i guess i'll just have to wait 'til next season to figure it out now that the car's going to sleep for the winter tomorrow. if anyone else has any opinions, i would be happy to hear them.
btw, thank you Ion, the tune you gave my buddy worked wonders (2mph in the 1/4), and i'm sure mine did the same, just can't tell all that much w/ a bad opti. just bad timing.
Old Oct 2, 2004 | 10:06 AM
madwolf's Avatar
Yep.... it definetely sounds like the opti. Nothing wrong with the tune if it ran fine in the other car.
Old Oct 2, 2004 | 10:20 PM
GR8RIDE_96's Avatar
ok, here we go again, now the scan isn't showing opti spark codes, or the pcm memory code, now it's showing the following: P0200 ( injector control circuit ), P0332 ( knock sensor circuit low voltage bank 2 ), P1222 ( injector control circuit intermittent )
WHAT IS WRONG WITH MY CAR???
Old Oct 8, 2004 | 09:23 AM
GR8RIDE_96's Avatar
Old Oct 9, 2004 | 09:55 AM
cndctrdj's Avatar
mine was doing the same thing kinda.... i kept getting different codes and then i started to blow fuses. check your grounds.... this is thebest advice i can give because thats the advice i was given... im still in the process of finding my problem
Old Oct 11, 2004 | 01:05 PM
nathan96's Avatar
Just a thought, I was getting a lot of weird codes, then came to find out the alternator was not giving enough voltage, which was confusing the hell out of the computer. Just a thought, check the voltage at the battery before starting and after to see where you are at.
Old Nov 28, 2004 | 11:02 PM
GR8RIDE_96's Avatar
just thought i'd see if there's anyone new out there with any other input before i go replacing everything ignition related......
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
