What Compression Ratio For N2O?
Old Sep 26, 2004 | 11:28 AM
Smokn '94 Z's Avatar
Question What Compression Ratio For N2O?
Hey. I am just wondering if I were to build my LT1 for N2O, what would be a reasonable compression ratio to have it set up for running 150 shots?
Thanks..
Old Sep 26, 2004 | 04:29 PM
RacinLT1's Avatar
Re: What Compression Ratio For N2O?
i wouldnt build a dedicated nitrous engine for only a 150 hit,build it for good n/a performance then spray it. 11:1 is fine and still allows pump gas with no issues,just build it with good forged parts.
I ran my stock LT1 with a 150-175 shot and had no problems,and it was a safe tune,i was in the process of leaning it out on the nitrous when my trans imploded.
Old Sep 27, 2004 | 06:28 AM
rskrause's Avatar
I agree with the previous post. However, you probably should select a cam with nitrous in mind - relatively long exhaust duration with a fairly narrow LSA. Basically, a good NA cam with some extra exhaust duration. Chose the static CR to go with the cam, aiming for a dynamic CR of ~8:1.
Rich
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
