60ft times bad help
Old Sep 16, 2004 | 09:10 AM
bandit383lt4's Avatar
60ft times bad help
alright guys and gals this is what i got hals frt and bk, bmr track pak -3 deg, lca with rel. brackets, sub frame conn, strut bar, 6speed and et street with 3.73 12 bolt running 1.9 60ft launching at 5500 rpm.... hals set at 5frt and 4 rear any help would be needed
Old Sep 21, 2004 | 11:23 AM
N20Dave's Avatar
Re: 60ft times bad help
What size et streets? I have almost the same setup except I have the Spohn t/a. I use 1-2 on the front hals and 5-7 on the rear with air bags in both sides. Left bag at 2 psi, right at 8 psi. I use a 27x11.5x15 qtp and my best 60' with motor is a 1.66 and spraying a 1.57. I launch at around 5000 with or w/o nitrous. Not sure what else to say. If you are running the 16" et streets series, there may not be enough sidewall to cusion the shock and that causes spin. It's a thought. Good luck.
Old Sep 21, 2004 | 11:41 AM
"White Knight"'s Avatar
wow......what elevation are you at.........i cut 2.0 on a totally slick street tire-with a basically stock car (exhaust and intake).
Old Sep 21, 2004 | 11:45 AM
Birdie2000's Avatar
Try loosening up the front shocks to like 1-2 to improve weight transfer, also maybe try a degree or two less pinion angle, somewhere between -4 to -6. Just readjust it for driving on the street.
Also, what tire pressure are you running?
Old Sep 22, 2004 | 11:50 AM
Ucantcme57's Avatar
Do the sway bar mod.. Your under 2.0 so that is at least a start.. play with your tire pressures, are you spinnign the whole time or what?
Old Sep 24, 2004 | 09:13 AM
glen63's Avatar
air bags maybe thats what i need. i run low 1.50s 60` 6.93 at 99.75mph in 1/8 best time for 60` has been 1.48 on stock rear end. been thinking about air bags but dont know anything about them yet. i run 28x 9 x15 drag slick on a 8" rim the rear end has 4:10 gears.
Old Sep 24, 2004 | 10:43 AM
jeremyferguson's Avatar
Is the clutch up to the task??
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
