injector help please
Old Sep 11, 2004 | 09:16 AM
SloLt1Z's Avatar
I currently have some lucas 009s(42.5) I am thinking of getting some Bosch 60# high impedence injectors, or should I go bigger and get a convertor box. here's a list of important mods.
353 ci Lt1 9.0:1 cr
Twin Ic'd D1sc (15 psi)
224/236 114lsa cam
Afr 190 heads
Old Sep 11, 2004 | 10:20 AM
rskrause's Avatar
Re: injector help please
Are you running out of fuel? Unless you are unable to get the AF ratio where you want it with the current injectors there would be no reason to get larger injectors. Assuming you need larger injectors, I'd advocate for the impedance converter as the low-z injectors operate much better at low load (short pulsewidths) than comparable size high-z injectors.
Rich
Old Sep 11, 2004 | 11:10 AM
Sean94Z's Avatar
Originally Posted by SloLt1Z
I currently have some lucas 009s(42.5) I am thinking of getting some Bosch 60# high impedence injectors, or should I go bigger and get a racetronix box. here's a list of important mods.
353 ci Lt1 9.0:1 cr
224/236 114lsa cam
Afr 190 heads
FYI: We have very similar mods and I had to go up to 72# to get the fuel I needed..
I Got the impedence converter and LOW-Z 72's and loved them both..
Old Sep 12, 2004 | 02:41 AM
Racetronix's Avatar
Rich
Yup!
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
