which is best to go with? Pilot bushing.
Old Aug 12, 2004 | 04:38 PM
CoUnTryMuZiCZ28's Avatar
Should I go with the regular Solid Bushing or should I get the roller Bearing? I have always used the Bearings but When i took my motor out the bearing was eatin up after only 2k miles.. There was like no bearing left.. BUt new motor and all is going in.. so should i stick with the bearing or use the bushing? Which one is quieter?
Old Aug 13, 2004 | 11:32 PM
Bud M's Avatar
Re: which is best to go with? Pilot bushing.
Bushings are less likely to fail from what I've read here. That's what LT1s come with stock.
Old Aug 14, 2004 | 10:30 AM
Serene's Avatar
ya sure the lt1s come with bushings stock?
What is the pn for the bushing?
Old Aug 15, 2004 | 08:14 PM
Serene's Avatar
ttt for questions about the bushing
Old Aug 17, 2004 | 09:54 PM
kostya_f's Avatar
I honestly cannot think of a reason a brass bushing would work better than a roller bearing. GM sells the pilot bearing which makes me believe that is what's stock. Autozone sells bushings if I'm not mistaken.
Old Aug 23, 2004 | 10:01 PM
WOOS1's Avatar
Autozone sells both the bushings and the bearings for an LT1. I bought the bearint (Timken), but not sure if I sould return it and get the bushing or not.
Old Aug 23, 2004 | 11:29 PM
Seems that i WOULD think that the bushing would be stronger.. I just want to know which to go with.. bearing or bushing...
HibachiZ28
Nov 6, 2015 12:53 AM
Bxlt1
Sep 29, 2015 03:18 PM
INFERNO
Mar 30, 2003 08:42 PM
