subframes
Old Aug 10, 2004 | 01:05 PM
BA383TA's Avatar
subframes
I have some SLP subframes that i need to have welded in. Who can weld them in and does good work and at a reasonable cost? How much does it normally cost? I've heard of people using muffler shops for this task. Im looking for a place in the frisco or lewisville area or nearby. Thanks Bill.
Old Aug 13, 2004 | 08:54 PM
bdc95ta's Avatar
Re: subframes
I used a local muffler shop the charged me like 40 bucks. Not bad, good job.
-b
Old Aug 13, 2004 | 09:27 PM
n2ceptor's Avatar
Re: subframes
Its true most muffler shops can do it, but just be careful and ask questions... You dont want "Joe Snuffy" doing a job that he has never done before... Make sure the shop has knowledge of what they are doing.... Cost can range from 30-60 dollars, depending on all that is involved...
Old Aug 14, 2004 | 01:21 AM
BA383TA's Avatar
Re: subframes
I've been calling around a little bit and it seems like nowone knows what subframes are. One shop said 200 dollars and then i said no way. I'll keep calling but if someone knows a place close to where i said then give me a hollar. Thanks very much, Bill
Old Aug 14, 2004 | 09:18 AM
camaro79323's Avatar
Re: subframes
i think rpm priced me like 75 to do mine a couple on months ago
call them up the are in lewisville.
later oscar
Old Aug 17, 2004 | 06:37 PM
v7guy's Avatar
Re: subframes
so did you guys get a solution to this? I've got to weld in subframes as well and I'm up in Irving, any suggestions? What did you do?
Old Aug 17, 2004 | 10:12 PM
BA383TA's Avatar
Re: subframes
I still haven't got them welded in yet. However I also haven't called RPM. I just want someone who will do it for cheap but a good price. I'm sure most people feel the same way. So the answer to your question is no I have not figured it out yet. If you do hollar at me nov194.
Old Aug 18, 2004 | 01:36 AM
v7guy's Avatar
Re: subframes
So this RPM place, can someone give me a adress and number, I'll call em and see what's up
Old Aug 18, 2004 | 11:10 AM
NBred94's Avatar
Re: subframes
Wherever you go make sure that they watch out for your fuel lines on the driver's side. You don't want a Camaro-BBQ
Old Aug 22, 2004 | 08:02 PM
jpw66's Avatar
Re: subframes
Not sure if this is assumed or not, but also make sure the car is on the ground as not to 'pre-load' the connectors. They should at least tack weld them while the car is on the ground, and then lift it if necessary.
Old Aug 22, 2004 | 11:51 PM
KyleBlue85Iroc-Z's Avatar
Re: subframes
I've heard this too. I've also heard it's a crock. I believe that even if it doesn't make a difference it's still something that would make sense. Drive on lifts would work too.
I got this off of LS1.com:
RPMotorsports
"there's no substitute for RPM"
107 E. Walters
Lewisville, TX 75057
972.434.2151
http://www.real-performance-motorsports.com
Kyle
Old Aug 23, 2004 | 08:03 AM
BA383TA's Avatar
Re: subframes
Thanks. Kyle
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Mar 13, 2016 03:37 PM
Henson071
Sep 18, 2015 04:01 PM
realistyc
Jul 28, 2015 07:32 PM
ducttape1975
Jul 10, 2015 06:29 PM
