New to the sixes and I have a stumble.
We just purchased a 95 firebird 3.4 and finally got it running today (had to have a locksmith fix the ignition lock cylinder) while driving the car if you give it throttle halfway decently it will stumble a bit and then smooth out. Ignition has been done and I am going to throw my scanner on it tomorrow, I think its the TPS but I have not messed with these cars just my 94 Z and was wondering if there is anything that might be wierd about the sixes I might be missing?
Re: New to the sixes and I have a stumble.
I need to check and be sure but the previous owner just installed new plugs and wires and swapped coil packs with another car to rule out those. It has a new fuel filter as well ( I saw it when checking the car over so I know its new) maybe just maybe the wires are bad or not totally on all the way, I will make sure tomorrow.
any reason in particular you got rid of your LT1 and got 3.4??
-just curious
oh BTW the TPS usually give the most trouble at idle in park or Nuetral- to diagnoise it w/o a voltometor (sp) simply unplug it and see what happens
-just curious
Well I put my scanner on it and everything seems to be reading correct except it says quad driver 1 and 4 are bad.
not sure what that means.
It also drives fine when cold but when it hits operating temp it starts stumbling and hesitating under load, you give it a good bit of gas and it will stumble a bit and then smooth out.
Maybe ICM? I will try to get that out next and check it.
not sure what that means. It also drives fine when cold but when it hits operating temp it starts stumbling and hesitating under load, you give it a good bit of gas and it will stumble a bit and then smooth out.
Ok, went back to the basics and I am sure this is the problem.
2 burnt wires.
I was assuming they were ok since they had been changed but I should have known better.
Putting new wires on tomorrow.
2 burnt wires.
Yep, put new wires in and routed them away from the EGR valve (which is what was doing the damage) and it runs perfect.
Thanks for the help guys.
ChrisFrez
Mar 17, 2015 07:31 AM
cmsmith
Mar 16, 2015 02:34 PM
crYnOid
18
Dec 20, 2002 02:58 AM
