Question on HTPP III
Old Aug 2, 2004 | 11:05 AM
DBrim's Avatar
Thumbs up Question on HTPP III
Has anyone ever experianced a horsepower lost after they used the Hypertech programmer on their LS1 engine? A few Tech mention to me that they Dyno a few customers vehicles after they use the hypertech programmer they lost power. How true is this?
I was thinking about getting a HTPP III and 160deg Stat!
Old Aug 2, 2004 | 10:51 PM
Capn Pete's Avatar
Re: Question on HTPP III
I *think* I feel a little extra power "kick" with my HPP3 program installed, and the throttle response seems a little "crisper" (due to advancing the timing I think) but it forces me to use the highest octane gas available (Sunoco 94) to prevent any pinging, so I wonder if it advances the timing too much??
I've heard where on a dyno the HPP has gained power, and where it has lost power. I think they're more worth it if you're doing gear/tire changes, and need to compensate, or for the A4's to adjust shift points.
Old Aug 3, 2004 | 02:57 AM
Compstall's Avatar
Taken from Hypertech's FAQ's:
"Hypertech Power Tuning is calibrated for stock or near-stock engines (engines equipped with high-flow air filters and cat-back exhaust systems). Any additional modifications that alter the engine's airflow and volumetric efficiency, such as installing a modified mass airflow sensor, high-lift or long-duration camshaft,ported heads, headers, supercharger, nitrous oxide, etc., would require new tuning. This tuning must be done individually on a dynamometer with a vehicle equipped with those parts. If you have modified your engine with aftermarket equipment other than a low-restriction air filter or cat-back exhaust, the Power Tuning developed for a stock engine may not be correct."
Old Aug 3, 2004 | 05:57 AM
DBrim's Avatar
Well I guess I will wait until I get the rest of my parts and get a dyno tune rather than buy the HTPP.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
SLIMJIM
Jan 7, 2003 11:06 AM
