Possible to sanity-check valvetrain timing without damper access?
Old Aug 2, 2004 | 12:31 AM
davepl's Avatar
Is it possible to sanity check the valve timing (ie: make sure you're not a full tooth off on the timing chain) without a degree wheel?
The physical layout of my car makes it difficult if not impractical to get at the balancer to attach a degree wheel, and there's no timing indicator.
I'm presuming the answer is no, but is there some other means by which cam timing can be checked to see if its at least in the ballpark?
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
grgguy
17
Feb 23, 2015 07:57 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
