2 codes need help!!!
Old Jul 31, 2004 | 02:52 PM
customlt1's Avatar
first code was maf malfunction..second code was auxilary input/output??? the only physical problem is reverse is hard to get into (m6)..if anyone could help me out i'd appreciate it..dont know how to go about this
Old Jul 31, 2004 | 03:06 PM
shoebox's Avatar
Re: 2 codes need help!!!
Please list the exact trouble code numbers. Depending on where they come from, the meaning may not be correct. Also provide some basic info about your car (like year model, mods, etc.). The signature is a good place to put that. If you want advice to be accurate as it can be, you need to provide as much info as possible.
Old Jul 31, 2004 | 03:18 PM
customlt1's Avatar
1997 trans am m6..52 k miles..i do have MAF descreened (the guy b4 me did that) and as i said b4 its a bitch to get into reverse and i think that has something to do w/ it..the code numbers are
p0100-MAF circuit malfunction
p1657-AUX imput/output
well thats what autozone said
Old Jul 31, 2004 | 10:50 PM
shoebox's Avatar
P1657 Skip shift/One to four upshift system control circuit
or maybe it was
P1667 Reverse inhibit solenoid control circuit
based on what you are saying about being hard to get into reverse.
Check fuses and wiring/connections to the skip shift or reverse solenoids.
P0100 Mass Air Flow (MAF) insufficient signal activity
Check connection at the MAF. The pink wire is the 12v feed. Sometimes it can get a little flaky. Check it with a meter, if needed. Should have 12v with the key ON.
Old Aug 1, 2004 | 12:32 AM
customlt1's Avatar
wheres the reverse solonoid?..are all these related somehow?
Old Aug 1, 2004 | 08:06 AM
The reverse lockout solenoid is located on the tailshaft, drivers side of the tranny:
http://cjcfo.fbody.com/members/injun...E/T56Conns.jpg
Check your fuses. My Chilton's shows different fuses for the MAF and the reverse lockout solenoid (96-97), but each year car can be a little different. Rob has the 1995 wiring diagrams on his Tech Pages.... take a look at those.
Old Aug 1, 2004 | 09:12 PM
customlt1's Avatar
fuses on the steering wheel panel or under the hood or?
Old Aug 1, 2004 | 11:35 PM
shoebox's Avatar
Probably under the hood. Use your owner's manual to tell you about the fuse usage.
Old Aug 2, 2004 | 12:21 AM
customlt1's Avatar
alright thanks guys..i'll check them out and get back to you..
Old Aug 3, 2004 | 11:26 AM
customlt1's Avatar
amp 20 the orange one was blown (fuse)..i replaced it and SES light is still on..do you know which code that blown fuse would of thrown? thanks
Old Aug 3, 2004 | 01:12 PM
If you replaced the fuse, and the items served by that fuse are now working, the SES light should turn off. It will only be on when there is a problem. If it doesn't go out, you haven't found the problem. You could double check this by pulling the "PCM BAT" fuse for 30 seconds to clear all the codes. You might want to scan it before you clear it, so you can see what the stored codes are.
Old Aug 3, 2004 | 08:16 PM
customlt1's Avatar
fuse blew again..the exact same one w/ no more than a 5 min drive..when i first started it i could put it in reverse w/ no problem..a trip around the block i put it in reverse and was a PITA..checked the same fuse and it was blown..any ideas?
Old Aug 4, 2004 | 08:52 AM
You have to look at the specific wiring diagram for your year car, and than find all the devices that are fed from that fuse. Check each device for a short, and if you find none in the devices, check the wiring from the fuse to the devices.
You could try replacing the fuse, disconnecting the reverse lock-out solenoid, and driving it to see if the fuse blows again. If it doesn't blow you've found the source of the problem. If it still blows, you know the reverse lock-out solenoid is OK - but not necessarily the wires - and you can look elsewhere.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
