Odd 02 readings
Old Jul 29, 2004 | 06:21 PM
OffspringZ28's Avatar
Odd 02 readings
I have my driver side oxygen sensor unplugged and on freescan it is giving off a reading. one 02 is giving off somewhere around 400 and the other is around 800. shouldnt it read different if it is unlplugged (from the extension)
Old Jul 30, 2004 | 07:49 PM
turbo_Z's Avatar
Re: Odd 02 readings
If the O2 sensor is unplugged then a scanner will show 450mV. The way you read O2 sensors if you were a PCM is 0mV means the mix is extremely lean and 999mV is extremely rich.. the median value would be 450mv and mean essentially nothing(ie. unplugged). You also get the same value of 450mV when you first start up your car because the O2 sensors are too cold to read any A/F charge.
reww86
Apr 27, 2015 06:14 PM
LingenfelterZ28
Apr 24, 2015 12:14 PM
NewsBot
Nov 25, 2014 11:20 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
dmaastr
9
Jul 1, 2002 02:22 PM
