What color to paint brake calipres?
Old Jul 26, 2004 | 05:23 PM
Aeromaks's Avatar
going to be changing front and rear pads and rotors and will be doing some suspension work at same time so figured why not paint them... question is.... what color?
I have a partiot red z with white zr1's....which i may or not may swap out for chrome ones....sooo. any suggestions?
Old Jul 26, 2004 | 05:26 PM
Aeromaks's Avatar
Re: What color to paint brake calipres?
http://f1.pg.photos.yahoo.com/ph/mak...c6.jpg&.src=ph
Old Jul 26, 2004 | 05:31 PM
AW/whiteZ-28's Avatar
Silver with black caliper decals or Black with stainless caliper decals.
If you change you white wheels. Which I REALLY think you should
Old Jul 26, 2004 | 09:55 PM
RedHottG2's Avatar
I like the black with stainless idea mentioned above
Old Jul 27, 2004 | 12:58 AM
tomatocity's Avatar
where can you get the stainless steel caliper decals? What kind of paint should be used on the claipers?
Old Jul 27, 2004 | 01:03 AM
StreamlineZ28's Avatar
paint them black then change your wheels. white doesnt look right on that color.
Old Jul 27, 2004 | 10:29 AM
Get decals from here in "brushed aluminum" http://www.bfranker.badz28.com/vinyl/vinyl.htm and I used duplicolor engine enamel on mine.
Clean you calipers cover your fender wheels with newspaper for over spray.
Leave the calipers on the car since you are shooting black over spray on other stuff in the wheel wells won't hurt.
Shoot the black (2-3 coats) let dry completely to touch, put decal on and spray clear (2-3 coats) let dry completely and put your wheel back on and your done.
Any paint on your rotor surface area is gonna burn off so don't be too concerned
Old Jul 27, 2004 | 03:29 PM
djn's Avatar
djn
Definitely black with silver Camaro, high heat decals, check with Brent: http://www.bfranker.badz28.com/vinyl/vinyl.htm , he's got the decals you'll need.
Check out mine in red with white letters, before and after the new silver pads where installed. Of course red is not your color stick with black.
95 Green Z28 Convertible
http://www.cardomain.com/memberpage/630092
Victor Lamb
Aug 26, 2017 02:52 PM
k1996z28
Apr 13, 2015 06:54 PM
Jubjub
Mar 19, 2015 10:23 AM
Brake_L8
Jan 20, 2015 09:44 AM
TransAm4utoenv
Aug 28, 2002 11:06 PM
