Quick ??
Old Jul 26, 2004 | 12:47 AM
94TA_LT1's Avatar
Quick ??
alright i have tunercat, and now i have the $EE file...so i downloaded it into the tunercat folder....now what do i need to do? thanks
Old Jul 26, 2004 | 09:52 PM
DarkHorse's Avatar
Re: Quick ??
First thing you need to do is pull your current stock .bin file out of your car. "Read PCM" so that you have a baseline of what your currently running. Put this file into a safe place and make a backup so if you screw anything up you can always go back to the original tune.
After you get that read, backup created and stored safely you can start simple. Idle adjustment, turn the fans on earlier, adjust the gearing (if applicable), etc....
Best thing you can do is use the search feature here and read, read, read, read, take a break and read some more. It's a lot to learn - i'm nowhere close right now but the learning part is cool as hell.
So, enjoy and good luck!
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
