how to paint berger panel?
Old Jul 25, 2004 | 06:18 PM
anasazi's Avatar
how should i paint my berger camaro piece?
i've got a back panel off another camaro, and its currently black.
the way i thought was the best way to do it is:
wash panel
sand panel to scuff it up (what grit?)
apply spraypaint primer
apply semi-gloss spraypaint
will this work and look good?
Old Jul 25, 2004 | 08:07 PM
firebirdjosh's Avatar
Re: how to paint berger panel?
I would use 300 grit. And I thought it was flat black, why the gloss?
Old Jul 25, 2004 | 08:31 PM
AW/whiteZ-28's Avatar
400 grit paper and use satin black or low gloss black I've got one in my garage I'm working on from time to time.
Old Jul 25, 2004 | 10:15 PM
anasazi's Avatar
spray paint will work OK and not look like it belongs on a honda?
Old Jul 26, 2004 | 10:41 AM
I've been using spray paint to see what it will look like and it looks fine, But I am gonna be using real car paint. (ie: acrylic enamel satin black)
but spray paint will be fine use duplicolor low gloss black engine enamel.
Old Jul 26, 2004 | 01:12 PM
Z28-CTYHNTR's Avatar
I used spray paint, came out fine. Sanded with 800 grit, Primered, laid down 3 coats of Satin Black, then one coat of clear (optional). You can see it in my sig.
Old Jul 27, 2004 | 07:42 AM
anasazi's Avatar
i've got some 400 grit to rough up the stock paint with, as well as some "automobile primer" from home depot, and some satin black spraypaint from home depot ...
man this is sounding ghetto lol
would it benifit me to sand it with something like 800 gritt between coats?
Old Jul 27, 2004 | 10:21 AM
Shoot it all at the same time primer wait until it "looks" dry then shoot whatever is next then so on. Flat type paints are easy to shoot
Old Jul 27, 2004 | 10:26 AM
Couldnt hurt, I sanded the primer coats after they dried. Its a lot easier than you think, just go for it. Imagine how much ***** I had to sum up since I used my own panel, I was real scuuuuured.
Aaront810
Aug 29, 2020 09:34 PM
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
92_RS_305
Sep 8, 2015 07:47 PM
